Shelf Vent Inserts?
post #1 of 8
Hello,
Does anyone know a company that makes and/or sells shelf vent inserts? These would be a plastic or metal part that are usually inserted into a custom cut hole of a media cabinet self (not a rack mounted item). I have seen them for sale before, but just can't locate any now.
Peace,
Dr. Z.
post #2 of 8
Originally Posted by Zeigh View Post
Hello,
Peace,
Dr. Z.
Could you use something like this?
http://www.lowes.com/pd_65044-34146-ABRGWH+1212_0__?productId=3260541&Ntt=return+grille&Ns=p_product_price|0
There are lots of different sizes available as well if you need something specific...
post #3 of 8
Yes, I could adapt an air conditioning vent grille, but was looking for something more form-fitting.
post #4 of 8
post #5 of 8
Airscapes,
Yo' da' MAN! (I can indeed speak much better English, but this just seemed fitting.)
Dr. Z.
post #6 of 8
No problem.. google is our friend..
post #7 of 8
Ahhhh, but just like communicating with my wife, I always have to find just the right words for any of it to work...
Peace,
Dr. Z.
post #8 of 8
Peace,
Dr. Z.
Tis True as the day is long!
