The original date for DVI and passthrough was end of Sepember or early October. I've been testing it and it is the same as the 3250, but it does hang once in a while. I still used fixed at 1080i for almost everything, and go to 480i standard when I watch a "widescreen" not in HD show on upn, so that my set can do the conversion. I don't like the fact that my set takes 3 seconds to change resolutions each time either.
FoxHD is still doing splicer testing. The color bars are up right now with a Dolby Digital signal (beeeeeep!) and the splicer logo way down in the lower right corner. I recorded a few minutes of it to have as test material for calibration.
Looks like it is partially installed and they are just trying to get the feeds set up.
vegggas
edit: My OTA Samsung box will hang and reboot if I try to hit the display button for the HD or SD fox channel. All others appear ok.
Edit again: As of 11:00 AM, no more reboots, but PSIP info is Central time.
Edit again: 11:28 FOX HD back on the air!
