I hooked up the OTA digital tuner (SIR T-150) to see what was now "out there" and compare cable feeds to OTA feeds. First, I compared feeds from the tuner using RGB. RGB had just a bit better "depth" and "sharpness" on all stations. I then compared the component output, which matched the output of the SA3100, IMHO, exactly. Component is not bad, just seemed softer than RGB. This makes sense as Component has less bandwidth due to signal derivation from RGB and RGB contains complete information from all three channels.
NBC Ch 2, eventually Ch 733 - Currently only available OTA as SD. Looks about the same as analog channel on cable, but free from ingress issues (ghosting). Good clean picture when I was testing with no noticable issues. This will be on cable channel 733 when it eventually goes HD and sends that signal to COX.
EDIT added info: NBC D is on cable Ch 123. Looks like a simulcast digital feed until they go HD. This could open the door to other stations offering digital simulcast.
FOX Ch 9 (came up as 5)- Currently only available OTA as SD. Looks about the same as analog channel on cable, but free from ingress issues (ghosting). Very soft picture and no current plans for HD content or broadcast. Cox would not carry this unless they went to a higher signal quality, as it offers no improvment over analog other than signal isolation, and is not in HD.
CBS Ch 7, Ch 730- OTA looks the same as cable, but there is no NCAA package for CBS OTA simulcast. The NCAA feed is sent to COX for distribution on 333 -335 and is the only available local option other than a $50 fee from Sat. The HD games are shown on CBS-HD on both OTA and Cable 730. The rumored extra channel for HD only content on 701 seems to not be needed right now, since it appears all HD games will be on CBS and would be duplicated. If an HD game is not carried locally on CBS, there is still a possibility of an insertion at 701 to show those games. Most primetime non-reality or news shows are good quality HD. Sports events are shown in true HD when available.
PBS Ch 11, Ch 731 - OTA looks the the same as cable. TRUE HD - Although it is a contious loop of the national feed.
ABC 12, 732 - OTA looks the same as cable, however, you also get the secondary SD version OTA in digital in case you don't have HD. Broadcast in 720p. Most primetime non-reality or news shows are decent quality HD. Sports events are shown in true HD when available.
Univision Ch 16 - Currently only available OTA as SD. Looks the same as analog channel on cable. No known plans to carry on COX since there is no improvement in signal quality and is not HD.
WB Ch 22- Currently only available OTA as SD. Looks the same as analog channel on cable. No known plans to carry on COX since there is no improvement in signal quality and is not HD.
KFBT Ch 29- Currently only available OTA as SD. Looks the same as analog channel on cable. No known plans to carry on COX since there is no improvement in signal quality and is not HD.
Telemundo Ch 40 - Currently only available OTA as SD. Unable to pick up with my antenna. No known plans to carry on COX since there is no improvement in signal quality and is not HD.
Discovery HD Theater Ch 700 - Cable Only. Looks great! Extra $5.00 charge per month. Now has movies, and is increasing their lineup selection.
HBOEHD and HBOWHD Ch 710, 711 Cable Only - Good quality upconverts and some original programming, but they do not usually use the original format. Instead they fill the entire 16x9 screen reguardless of format. Included free with standard HBO subscription.
SHOEHD and SHOWHD Ch 720, 721 Cable Only - They typically use the Original Aspect Ratio, so 2.35 movies are shown in their correct aspect. They have broadcast boxing events that look great in HD and are planning on many more live events. Included free with standard SHO subscription.
NOTE that SHO East is not available in the lineup anywhere else other than the HD format so users get an "extra" channelwith HD.
No comments heard on future programming such as ESPNHD, CINEMAX, or others (doen not mean they are not available). HDNET was rumored, but unless you were a partner with Mark Cuban, the pricing was VERY high. My opinion is that the pricing would have to come down before we see it in "non partnered" cable systems.
vegggas
