AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Krell Foundation Owners Thread
Krell Foundation Owners Thread - Page 43
post #1261 of 1268
Originally Posted by jsetliff View Post
Anyone doing FLAC file streaming from their OPPO 95 or 105 to the Krell via HDMI? Display on Krell showing Full Range + Sub. Is my only option to have the Oppo perform the DAC? No way to send bitstream to Krell in this case? (Maybe something in Oppo setup? HDMI in Oppo already set to Bitstream) If it can't send bitstream in this case, maybe better to use the XLR Balanced inputs from Oppo to Krell for this. I have the Oppo 95, but wondering if 105 users are able to send bitstream thru HDMI from Oppo when playing network music files.
Originally Posted by rhale64L7 View Post
You should have all options available for bitstream hdmi into Foundation. I used to listen to stereo all the time. If it is in 5.1 the Foundation will pick that up. I have the 105 the 95 is the same I think in this regard. I used hdmi for everything. The dac implementation in the Foundation sounded superior to me. More bass punch and superior depth of soundstage.
I don't stream from my Oppo but do stream from a Qsonix to the Foundation in WAV and FLAC with no issues. I love using Neo6:music for my FLAC files. Sounds amazing through the Foundation.
post #1262 of 1268
Hi Guys,
New foundation owner here. I'm having problems performing the software update via network. My current firmware is v1.08. I successfully check and commence the update process via Ethernet and the processor appears to successfully update the numerous files required. It finally gets to reporting "webpages.inf 100%" and then sits there. At this point, I have tried pressing enter, turning the power off via the front panel switch, and unplugging power completely all with a lack of success. When I check the firmware it still reports v1.08 and again finds an available update.
Am I missing something here -is there something else that I should be doing? I've so far wasted a good 2-3 hrs trying to get this to work to no avail and would really appreciate it if someone could please point me in the right direction.
Sean
post #1263 of 1268
Originally Posted by seanoo View Post
Hi Guys,
Sean
Call Krell you cant update from that old a version to the new version. They have to send it to you. Or maybe someone in here can send it to you.
post #1264 of 1268
Thanks Ron. I'm located in Australia so will drop them an email. If anyone does have a copy of later firmware I'd sincerely appreciate it if you could PM me a copy. Thanks Sean
post #1265 of 1268
Hi Sean, Have you tried your optical and coax inputs? If you have a model with that old firmware you might have one of the older models that might need to go back to Krell for repair. Models from before I think Sept '13 has that issue.
post #1266 of 1268
Yes, unfortunately, I have the same issue with digital coax -haven't tried optical. This is going to be a real pain as I purchased from a fellow AVS member in the USA but am located in Australia.
Edited by seanoo - Yesterday at 9:20 am
post #1267 of 1268
Great timely response from Krell regarding the software update issues. Now have the required software in hand.
post #1268 of 1268
Good deal.
