AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Acer k330 cartoonish image problem
post #1 of 3
Even the internal media page is doing this. However the screen (it says ACER) that comes up when you first turn it on is perfect.
Is it possible to adjust this projector more than the simple menus? I've tried all of the buttons... it's a frustrating remote...
This is thru HDMI. It is also doing the same thing thru the video and vga ports.
Any idea what I can do to fix this?
I did a short search before posting but I wasn't exactly sure how to describe the problem. Searching for distorted image seemed futile.
Tom
post #2 of 3
I picked the projector up to move it and the image got better for about 2 seconds. I haven't been able to duplicate it but to me it means there is a hardware issue.
For the record I bought it on eBay. And it has a 30 day replacement warranty. Might see about getting my money back and just getting an LG 301 or 350.
Tom
post #3 of 3
Just an update in case anyone is losing sleep over this.
OK. Seems to correct itself when you lightly press the top. But only for split second and then it loses the picture and reverts back to the beautiful start-up screen. Does it on all inputs not just HDMI, with DTV and DVD and thru usb too.
I'll only post on this again if I find a solution.
