AVS › AVS Forum › Display Devices › CRT Projectors › Raise the Red Can
Raise the Red Can
post #1 of 2
Hi,
I have a Barco 808s that totally rocks.
However, I'm about 95% of the way to a perfect set-up and have found that I need to raise the red can just a tiny bit to bring it into true.
Can someone tell me where I can find the adjustment to do so?
It is flat ceiling mounted.
Everything else is PERFECT.
*can you tell I LOVE this projector*
Shelley
post #2 of 2
You need to slightly adjust the red V **** control. Set the vertical shift setting in the menus to 50%, then adjust the control here:
http://curtpalme.com/Barco808_Layout3.shtm
Feel free to join our forum here, it's got a lot more CRTers on it than AVS, although AVS was very busy back in the day:
http://www.curtpalme.com/forum/index.php
Curt
  Back to Forum: CRT Projectors
