AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Half screen
Half screen
post #1 of 22
Hi to all! I am first time posting my problem. I got A plasma 50" TV Panasonic model TH50PX80U
it's been making a issues for a seconds and back well but recently the screen show only half (top) and the another are gray I tried to fix myself replacing the both SC boards SS and Y-Bord too but still same problem any clue to fix it? May be the panel is going bad?
Any help are highly appreciate !
post #2 of 22
There is a member here, tom669, that is very good at sorting these problems out. Hopefully, he will see this thread and reply. If not, you could try to PM him.
Good Luck.
post #3 of 22
If the bottom half is grey (not black or otherwise faulty) then I'd be looking at the "AD board". PM me if you want the service documentation for this set.
post #4 of 22
Thanks Tom666, and appreciate your post . I've the SM already n isn't showing any kind of this particular issue, Picture and audio well but
only half screen. I opened and carefully inspected all boards two from they got green led it's lit up when TV is on
I replaced the buffer board only but without luck.
Can you show me where's the a "AD Board" location ?
post #5 of 22
I think Tom means the A board or the SD board. Probably the SD. There is no AD board in the 50px80u.
If you have the SM, you have this diagram:
A nice solid TV. I had one.
Good luck,
Larry
post #6 of 22
From the manual:
9 Self-check Function
1. Checking the IIC bus lines
2. Power LED Blinking timing
9.1. Check of the IIC bus lines
9.1.1. How to access Self-check indication only:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [OK] button on the remote control for more than 3 seconds.
Self-check indication and forced to factory shipment setting:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote control for more than 3 seconds.
Post a picture of what it shows after running the test in 9.1.1. To exit, you unplug the unit from the wall or Surge strip if you have it plugged into one.
post #7 of 22
AD board = A+D board combined. I think they called it that on the 2007 series. Anyway, it is "A" board only now even though both functions are in one board. I reckon that is the fault, but you can do the test above and also a "mirror" test later (see SM) to narrow it down to A board.
post #8 of 22
Thanks again Tom669!! I'll do it today n let you know later!!
Have a wonderful Monday
post #9 of 22
I be back again ! Sorry. I was out the town for a few weeks,So thanks to all and i followed all suggested recommendations from you guys but i still with the same problem I entered to service mode n show part of the guide table to adjustments. Conclusion:.... Bad panel...... Anyway thanks to everyone and appreciate your time..
post #10 of 22
I would not agree that half screen fault would be a bad panel unless your SD board fails again.
post #11 of 22
Well, I did it. Replace early before (to be entered to this forum ) the Y Sustain board and couple of buffers up/down also x board too with the some result. I am not electronics repair expert but I've been read the SM for this set. I have knowledge on electricity my actual job ! Tom you think i need replace C1,C2 and C3 board ? those not be replaced yet.
post #12 of 22
Can you supply a picture of the problem? Is the faulty half glowing, any pixels lit?
post #13 of 22
Sure! Tonight I'll do it,
Thanks for your help Tom.
Pd: It's really not showing half screen it less that, About 6 or 7 inches top screen (horizontal)
post #14 of 22
Here you go! Is about 7 inches at top across the screen.
Edited by B-videoser - 10/4/13 at 8:04pm
post #15 of 22
So, from those 7 inches onwards, pic is blank?
In a dark room can you see any glow from the blank portions?
post #16 of 22
Absolutely NO! just you can see dimly light on the rest of screen.
Thanks Tom for your help and time.
post #17 of 22
OK, this indicates you most likely have a bad SU or SD buffer board.
See which portion of the screen is not working. The screen is divided into two halves vertically.
If the top half does not work properly (part or all is missing), replace the SU board.
If the bottom half does not work properly (part or all is missing), replace the SD board.
post #18 of 22
I did already !! I mentioned on past pot that, The missing or blank picture is more than 3 quarter of screen. It's across (horizontal) not vertical issue. What are think?
post #19 of 22
Can you post a FULL image of your screen and not an image of part of it then, displaying something like a TV picture or analog snow. No where above do you say you replaced the SU or SD boards, am I missing something?
post #20 of 22
No! You right! There is
post #21 of 22
Hey Tom669 what is your final diagnostic refer to that particular issue?frown.gif
post #22 of 22
Sorry, did not see your post, but that is an SU board failure there. Only need to replace SU, not SD or SC, in this case.
