AVS › AVS Forum › Home Entertainment & Theater Builder › General Home Theater & Media/Game Rooms › help please to ensure TV does not slide off the rails of cheetah flat tv mount
post #1 of 4
I have the following mount on the drywall
APDAM2B
http://www.amazon.com/Cheetah-Articulating-Bracket-Displays-Ethernet/dp/B000WL6YY8/ref=cm_cr_pr_pb_t
The 65 inch plasma TV barely fits on the mount rails. I am afraid it is going to slip off.
There are bottom screws but not sure how adequate to prevent slide off.
Anybody have any suggestions to arrest any sliding.
post #2 of 4
No one has this problem?
post #3 of 4
May I suggest temporarily removing the TV from bracket attached to the wall and performing the following small modification to your TV mount.. All you need is a drill, drill bit and a two 1" long #6 machine screws, 6 or more small washers and 2 matching nuts. Basically you create a stop at the end of the mounting rail, or up against the inside part of the tilting bracket attached to the TV.
Edited by weaselfest - 10/9/13 at 4:03pm
post #4 of 4
The side flanges on the mounting rectangle don't prevent the vertical brackets from sliding off the rails? From the photo on Amazon I don't see how it could slide off.
