AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › Copying to the 515
Copying to the 515
post #1 of 3
I want to record some old beta tapes to DVD using the Magnavox 515.
When I connect the beta machine to the front of the 515 I get audio and no video. When I connect to the back I get video and no audio.
Has anyone else had this problem?
post #2 of 3
You need to connect composite YWR RCA or S-Video+W/R audio to either the back or the front, then open the Video > Video Input menu and select the appropriate input type... L1 (back) or L2 (front) "Video In" if YWR RCA or "S-Video In" if S-Vid.
post #3 of 3
Thank you. I didn't know about the input menu.
  Back to Forum: DVD Recorders (Standard Def)
