Herein I shall drop Ray's UNIQUE FIELD REPORTS . [These are best appreciated when played back through a text reader app].D
FIELD REPORT (16AUG13) DAY-1:
REC on project.
Screening room is new construction on 61st floor of new building. Penthouse suite for X.
Working with crew of (nationality mix) fellows. These folks were not given enough detail on preparation of sub-systems. Hence, the going is quite slow.
Projector Data:
Christie Mirage HD20K-J; SN: 308368001
Lens; Konica-Minolta, fixed zoom 1.12:1; SN: 3635623B00657
Tasks Performed:
1) Worked with local crew to install Brand X "lazy Susan" hanging platform unit. This took the crew the better part of the day as there were major cuts and changes that were required to clear the existing cosmetic frame installed already, and mount the new Brand X platform unit. The hanging threaded rod used on the BrandX unit was barely long enough to fit. We adjusted the platform to the lowest possible position on the threaded rod and I hope to have enough lens shift to get the image below the ceiling protrusion (the lap pool floor above the screening room requires a significant "soffit" protruding down from the ceiling between the lens of the projector and the screen position). REC will test as soon as we have permanent power to the projector.
2) Dug around the storage room and found:
- Lens
- Floor racks
- 3D kit
- BRAND X power conditioner
- 2 x racks for front of house
3) Assembled and installed Floor Racks. This took the afternoon to install as the carpentry needed heavy modification. The crew modified the sub flooring for the rack to fit properly and they are installed. However, the cosmetic wood doors and panel must be replaced. REC notified Project Manager and crew, and the new facia material is being planned and ordered. The reason the facia must be replaced is that the two-door access panels they designed do not allow for servicing of the rack equipment. The openings are shifted and the are too small to pull-out the rack slides.
4) Mounted the Brand X power conditioner in the right floor rack (as seen facing the rear of the screening room) at the bottom per spec. Gave direction to local staff for electrical run of raw power to conditioner, then another line from the output of the conditioner to the projector.
5) Organized screen and screen frame parts. NO ASSEMBLY INSTRUCTIONS! REC to work with assembly tomorrow.
6) Directed local staff on cleaning the two front of house cabinets and mount the two equipment racks therein.
7) Had the local staff make a power cord for the projector and performed a power test of projector. The Christie powered up, and gave a lamp door open error. Thanks Brand X. REC will troubleshoot and repair tomorrow.
Also, REC had a fun experience with electric muscle therapy on the left thumb as he was powering down the unit. Apparently the test power feed (coming through an extension cord, power strip, and temp power box that may be faulty) had a nice level of AC power (ed.240Volt) riding on the neutral causing the thumb muscle to constrict. The point being, REC will await the final power from the electrician before running the projector for any length of time.
8) REC met with the ventilation contractor. Since there is only extraction being supplied to the projector "hush-box", it is irrelevant where the extraction takes place. Currently the extraction duct terminates just above the rear of the projector in its present position. REC OKed the position and no further work is planned on this matter.]
THE FUN BEGINS:
DAY-2 REPORT (17AUG13):
REC on project.
REC is at full-stop due to missing hardware for screen frame and leg assemblies, as well as final power to projector not yet complete. However, we did get some things done this morning, and the local team is working on assigned tasks this afternoon.
REC back at hotel.
Tasks Performed:
1) Assembled screen legs. Required "robbing" screws from the existing mounted plates as there is no hardware for the screen legs or frame on-site. All six legs are assembled and wheels mounted.
One of the local team is out searching hardware stores (on Saturday) for US Inch-standard hardware.
2) Moved large masking frame assemblies (x2) (Left and Right assemblies) into screening room. Ready for assembly once we have hardware. Also, small center link sections are in screening room awaiting assembly. Top and bottom motorized masking units are not yet moved into screening room as there is no space to store them while work is being performed. These units will be moved in when hardware is on-site.
3) Local staff pulled power cable between IS20 and projector. Cable was not yet terminated at either end. REC showed local staff wired remote cable for projector and they will pull that cable this afternoon.
4) Installed front of house racks into cabinets. Removed shipping plates. Cabinets are clean and ready for final wiring and equipment mounting. Racks are not secured to cabinets, hence, the racks can be moved around to accommodate equipment installation. Removed rear doors of racks as they are useless once installed in cabinets.
FYI, cabinet doors were removed yesterday to eliminate the possibility of damage while rack were being installed.
5) Organized projector accessories and placed in projector "hush-box".
Tasks for Tomorrow:
REC plans on being on-site at 09:00 tomorrow morning. However, several things are required to be completed for any progress to be made. These are:
a) Power for projector complete.
b) Hardware for screen on-site.
c) Screen channel speaker cables pulled per Cineramax spec. Cable at rack cabinet end must be long enough to protrude from the front edge of cabinet at least 2 meters.
d) Flooring for behind screen installed.
e) AC power for masking motor system.
If above liste ditems are complete, the following tasks can be performed:
1) Install screen speakers, terminate speaker cables at speaker end. Amplifier end of cables will be labeled.
2) Complete screen assembly and power-up masking system.
3) Repair Christie projector ("Lamp Door" error).
4) Align projector for best image.
All,
First of all, thank you very much M! The installation of the carpet in the screening room was a wonderful surprise this morning! The flooring crew came in this morning and finished taping the protective plastic cover over the carpet. This also has greatly reduced the dust in the room; which is important as we run the projector. M, please refer to the end of this email for a list of things we need to get done tomorrow.
NOTE: The internet connection at the hotel has just been repaired. The internet was dead since 04:00 when I woke up this morning.
It is critical, I believe, that the screen is fully installed and projector alignment completed regarding image position and geometry with final masking positions set before I return to the US. Since it will take the better part of the day to assemble position and align, if we do not have hardware by tomorrow, I will have to extend the visit. If Stewart can ship a kit Monday, perhaps we can receive by Wednesday. I can adjust my schedule; I just need a decision from you gentlemen.
DAY-3 REPORT (18AUG13):
REC on project.
REC arrived at 08:30 to find that the flooring crew installed the carpet in the screening room overnight. This was a very welcomed site as we can now place the screen channel speakers and the dust level in the room has been lowered dramatically. Thanks M!!
Tasks Performed:
1) Connected input 240VAC to IS20 power conditioner.
2) Connected IS20 power conditioner output to New Christie projector.
3) Repaired "Lamp Door" Error on projector.
4) Powered up Christie projector and verified image positioning. (See attached photo) Performed lens shift and brought up aspect ratio target test pattern. Although the screen was not in place, it appears that we can set this system up for a 2.35:1 aspect ratio and make all image ratios work within this image positioning. The image you see in the photo is full-chip image. The 2.35:1 removes about 20% from the height of the overall image and as stated previously, should work with the new screen.
Full alignment will be performed when the screen frame hardware arrives.
Tomorrow we will address the installation of the screen channel speakers.
M Team Tasks:
1) We need to drop an air input into the projector box. I will show the team tomorrow where the duct needs to be placed.
2) We need to have all power to front racks completed.
3) We need to have the speaker cables pulled.
4) Projector wired remote cable needs to be pulled.
5) Move all screen channel speakers into screening room. I will terminate the cables at the speakers.
6) Turn on air conditioning systems in screening room and keep door closed.
All the Best,
Ray Callahan
President
Callahan Digital Cinema, Inc. (CDC)
4510 NW 102 Court
Miami, FL 33178
786-336-8219
rec@callahandigitalcinema.com
www.callahandigitalcinema.com
Gentlemen,
Enclosed is the report for 19AUG13 (Day-4). Good progress today (and I received a treat of great Turkish baklava!). Front of house should be completed as far as we can go today, except for the two speakers that are “high-mounted” at the stage position. Peter, I need your direction on how these two speakers are to be mounted.
DAY-4 REPORT (19AUG13):
REC on project.
REC arrived at 08:00.
Tasks Performed:
1) Moved all five LF cabinets (QSB-1218) into theatre.
2) Moved all five Full-range cabinets (LT-20C) into theatre.
3) Reviewed speaker wiring with local staff. Local staff installing speaker cabling today and will complete today. All speaker cables will have 2-meters of service loop at the speaker, and 4-meters of service loop on at the audio rack end. This will provide enough length on the cables to extract the rack with the cables laced.
NOTE: M's crew decided to go with a flexible cable wrap system ("snake-skin" or equivalent) instead of a cable trough (e.g., Panduit). Hence, no need to provide Panduit cable management systems. I agree fully with their decision.
All speaker cables will be pulled and terminated at speaker end today. All screen channel speakers will be stacked today.
The nomenclature being used for the cables is as follows:
L = Left Channel
LC = Left Center Channel
C = Center Channel
RC = Right Center Channel
R = Right Channel
Refer to the attached drawing for individual speaker wiring, and label template. All cables are labeled at both ends with a Brother label making device (Black on White tape).
4) Corrected cabling for floor racks. Installed lacing braces.
5) Held meeting with M and mechanical trade on cool air input system for projector "hush-box". They will be adding a drop as requested.
6) Met with M and cabinetry craftsmen regarding front of house rack floors. A compromise was reached and although they cannot remove the floors of the cabinets housing the racks, they will build a genlte slop ramp assembly for each. Thereby allowing the rack to be rolled out of the cabinet for servicing.
7) Requested that one more of the side vertical braces for the projector "hush-box" be removed. This is needed to allow the projector to be rotated on the lazy susan a full 90-degrees for lamp replacement and board servicing.
8) Electrician should have power for both of the front of house racks completed today.
9) Forgot to ask M on the mounting specifics for the exterior camera. Will take care of tomorrow.
10) Asked M about extension of stay. They have not yet decided.
11) Requested that air conditioning be turned on in the room. Only the small units mounted in the front of house racks can be used now. Main AC system will not be ready for some time.
12) Searched storage room for various equipment for Cineramax portion of job. Need a list of specific equipment WITH MANUFACTURER, MODEL, & SERIAL NUMBERS before continuing search as there are several Creston, Middle Atlantic, and APC units at the site. I do not want to install the wrong unit.
Gentlemen,
Today produced great progress as the missing hardware for the Stewart screen system was found and delivered to the screening room. I have no idea where this box was, but thankfully the delay was terminated. It certainly did not look like it came from the dusty storage room.
We completed the screen and masking assembly, which took the better part of the day of all crew members and some help from the other trades available.
Although good progress was made, several key issues stopped us from achieving our goals for the rushed last day of cinema expertise on-site. This is unfortunate, yet the decision was made to not extend, and this is what we have.
Although there was a directive given that the screening room must have 3D going tonight, that is impossible as the Christie light engine has failed as you can see in the photos. I could possibly repair this, but as you have decided, I am departing for Miami tomorrow morning.
As both of you are well experienced project managers, you clearly understand that sometimes things happen beyond your control and schedules slip. This is one of those times. The local crew assisting me during this visit were very energetic, kind, and helpful. Yet they had no experience in these systems, and I taught them thoroughly on what to do. The language barrier itself was challenging for all of us. I am personally disappointed that our team was not able to achieve the goals of this visit. Yet as a 30+ year professional in this industry, the goals were unachievable in the original timeframe allotted due to the various challenges.
I believe you all have Mr. Mike Babb coming in to this project in a few weeks. He is a highly skilled Digital Cinema Engineer, and I believe equal to my level of expertise (although he always states he is my junior). He will “carry the ball” for you all quite well and finish this project for you.
DAY-5 REPORT (20AUG13):
*** The light engine (or TI section) in the Christie projector has failed.
REC on project.
Tasks Performed:
*These items are based on a specific list provided by Peter.
1) Complete speaker wiring and stack.
DONE
2) Complete screen and masking assembly and position as far forward in the room as possible.
DONE This took most of the day for all crew involved. around 09:00 this morning a package arrived for us. This package contained the masking motor controller and ALL OF THE BOLTS AND ACCESSORIES WE HAD BEEN MISSING FROM DAY-1.
3) Install power outlets and make them live at:
- Projector hush-box
- Floor rack
- Front two racks
NOT DONE The staff made connections at the makeshift breaker panel, yet they did not have the receptacles on-site to complete.
4) Pull all interface cables between floor racks and projector box.
NOT DONE The staff ran out of time today.
5) Pickup from Storage Room a Crestron processor series 2
NOT DONE Could not find in storage.
6) From Storage Room get Crestron accessory rack
7) 3 x Crestron devices 3 relay cards
8) Find Fiber Optic Transmitter receiver and try to install
9) Install 3D polarizer
NOT DONE Could not mount.
10) Assemble and install screen and push screen as far forward as possible
DONE This took most of the day.
11) Push projector back as far as possible.
DONE
12)Center on screen the lens
ATTEMPTED, BUT... The room is 20'-10" wide as measured from wood trim at lens height and position in the room with a Hilti PD-30 Laser distance measurement device. This places the center at 10'-5". REC moved the projector on the lazy Susan as much as possible to gain the center position, yet the best we could achieve is an offset of 3" to the right (as viewed facing the rear of the room). Hence, as viewed facing the rear of the room, the left-side measurement is 10'-8", and the right-side measurement is 10'-2".
Mehmet, the architect, and the furniture craftsmen all met today in the screening room and also measured with a higher-end laser system and compared to the center of the screen. This confirmed RECs original measurements and they are devising a plan to correct (I believe). See Mehmet for details.
13) Determine Dimensions of Porthole
NOT DONE Since the "hush-box" is in flux, we determined that this measurement must wait until the final position of the projector is determined.
14) Prepare 6 aspect ratios (1.33, 1.77,2.20, 2.39, and 2.65 Ben Hur).
NOT DONE No power to masking motor system.
15) Get 3 x IEC power cords with Schuko plugs (oppo and the XL Mover)
NOT DONE I did not receive any cables.
16) Regarding Height Channels (locate their brackets) and install as shown below and according to Peter’s original blue prints.
NOT DONE Could not find brackets.
REC recommended that this trip be extended to all decision makers early-on as we had a massive delay due to the inability of assembling the screen and masking system due to no hardware. The decision was advised this morning that there would be no extension of the trip. Hence, REC will depart Moscow tomorrow morning bound for Miami.
UPDATE, I have some pictures to show but long story short: I am letting Ray Stay 2 more days and he is instructed to take projector boards out and reseat, apparently the projector took a banging because the lamp door open error message in hindsight was it's very own symptom, that was followed by this crazy ass blue convergence pattern distortion. It looks like the convergence on blu is on, but no, it is a malfunction, most likely a Formatter board loose. Christie gives it a chance (being greater than 75%) that is is a loose board. So the knot on everyone's throats continues for at least 24-48 hours.
I am glad that Ray is staying because we will recenter the projector, and obtain some longer threaded rods that will address the need to extend the polarizer support which due to the swimming pool's soffit (lap pool is above) did not permit to properly line up the polarizer.
Gentlemen,
Today was a productive day for the crew. Although I was not able to fix the projector with materials on-hand, Peter has given direction to move forward with alignment using the broken projector to bring up 3D, etc. The mechanical crew came in today and spent the day installing the exhaust and A/C input into the projector cabinet.
Removed the projector from the projector mount and placed on floor for troubleshooting. While I was troubleshooting, this allowed the mechanical crew space to get their duct work done. I also loosened the mount on the track rail and moved the base to attempt the elimination of the 3” offset of the lens position on center of the screen. I was able to move it in the correct direction about 1.5”. I will have a specific measurement when we put the projector back into the mount. Also, readjusted the top plate of the Brand X mount to allow the proper positioning of the MasterImage 3D z-screen.
NOTE: The wired remote control cable for the projector is too short to reach the floor rack. There are several ways to remedy this issue. Peter, please advise on how you want to fix this matter.
We will reassemble the projector to the mount and should be able to playback rough images tomorrow afternoon. Fine alignment will be performed either tomorrow afternoon, or Friday morning.
We are looking much better than yesterday.
DAY-6 REPORT (21AUG13):
*** The light engine (or TI section) in the Christie projector has failed. The standard connection checks and reseating of cables and connectors was performed without resolving issue. Full report has been provided separately. REC will continue with alignment with the current projector with the issue. Projector will be replaced or repaired later.
REC on project.
Tasks Performed:
DONE
- Projector hush-box; NOT DONE The staff made connections at the makeshift breaker panel, yet they did not have the receptacles on-site to complete.
- Floor rack; DONE
- Front two racks; NOT DONE The staff made connections at the makeshift breaker panel, yet they did not have the receptacles on-site to complete.
DONE
DONE
DONE
NOT DONE Could not find in storage. Asked Mr. M
DONE with power up yet awaiting mount.
10) Assemble and install BRIC masking controller.
DONE Will test and align in the morning.
DONE
12) Center on screen the lens
IMPROVED Shifted Brand X hanger on rail channel as much as possible (now snug against the cosmetic box frame. Gained a couple of inches. Will check how close we are when projector is remounted. (Projector had to be taken down to the floor for troubleshooting of the "blue vertical lines" issue.
14) Prepare 6 aspect ratios :1.33 (FULL HEIGHT OF SCREEN), 1.77(FULL HEIGHT OF SCREEN),2.20 (FULL WIDTH OF SCREEN), 2.39 (FULL WIDTH OF SCREEN), and 2.65 Ben Hur (FULL WIDTH OF SCREEN).NOT DONE No power to masking motor system.
16) Regarding Height Channels (locate their brackets) and install as shown below and according to Peter’s original blue prints. NOT DONE, could not find brackets.
**NEW**
17) Mechanical crew (3 guys) came in this morning and began the installation of the duct work for the projector exhaust and A/C feed. They should finish today.
18) Found Oppo player and ready for playback when projector is remounted.[is it the correct one?]
19) Powered-up Master Image 3D system and readied for playback. Modified Brand X mount plate and the system is ready to assemble tomorrow when mechanical crew is completed with their duct work.
20) Mr. A completed the connection of the two air conditioners in the front of house racks. The screening room temperature and humidity has been improved.
Gentlemen,
Today was a productive day for the crew. We have the projection system remounted and assembled in the “hush-box” location. The crew ran power to the locations we needed and the system is running. However, we found a problem with the 3D polarizer panel that we are working with the manufacturer now to resolve.
Final alignment is planned for tomorrow for at least 2D, and we will do our best to resolve the 3D issue with the LCD polarizer. If we are able to resolve the 3D issue, we will alert Mehmet and have a short demo for the client with the Avatar disc tomorrow early afternoon.
DAY-7 REPORT (22AUG13):
REC on project.
REC arrived at 08:10.
Tasks Performed:
1) Install power outlets and make them live at:
- Projector hush-box; DONE The staff made connections at the makeshift breaker panel, yet they did not have the receptacles on-site to complete.
- Floor rack; DONE
2) Pickup from Storage Room a Crestron processor series 2
3) Find Fiber Optic Transmitter receiver and try to install
NOT DONE Could not find in storage. I was informed that this device will not arrive in time for installation this week.
4) Center on screen the lens
IMPROVED Shifted MiT hanger on rail channel as much as possible (now snug against the cosmetic box frame. Gained a couple of inches. Will check how close we are when projector is remounted. (Projector had to be taken down to the floor for troubleshooting of the "blue vertical lines" issue.
5) Determine Dimensions of Porthole
6) Prepare 6 aspect ratios (1.33, 1.77,2.20, 2.39, and 2.65 Ben Hur).
NOT DONE Need to program masking motor system. Also, since we do not have a reference disc, we will be aligning the various aspect ratios by on-site calculations.
7) Get 3 x IEC power cords with Schuko plugs (oppo and the XL Mover)
DONE The crew made cables, and found some to gather power from the APC power conditioner.
8) Regarding Height Channels (locate their brackets) and install as shown below and according to Peter’s original blue prints.
NEW
9) Mechanical crew (3 guys) came in this morning and finished the A/C tie-in for the cold air feed to the “hus-box”.
10) We are also missing the two small screws that mount the z-screen fan assembly.
11) Re-installed all projector and 3D equipment in “hush-box”.
12) Attempted to install Oppo BluRay player in front right rack. Found that long HDMI cables (that were previously pulled) are non-operational for signal without boosters. Can’t find boosters, hence we moved the Oppo unit to the back of the room and we are using a shorter HDMI cable and signal is good at the projector now.
13) While attempting basic 3D playback of Avatar, found that the MasterImage MI-WAVE 3D unit has a fault with the LCD polarizer screen. Troubleshooting with MasterImage engineering now. Hopefully will resolve in the morning.
Gentlemen,
I have gone as far as I can with what we have here. Please read details below as there are many issues. In summary, the projector is aligned for the Avatar 2.1:1 aspect ratio and 3D is non-operational as there seems to be a failed LCD polarizer panel. Repaired masking system as right side was jamming due to a loose bolt on one of the slides. Set up masking for “USER-1” button on controller.
The A/C and exhaust duct work is done.
The electricians are now working on all of the final connections to the main breaker panel. This should help Peter’s team greatly when they arrive.
I left some basic hand tools and test equipment with Ali’s team. They may need these tools for the various work they are doing, and I wanted to thank them for their gracious assistance during this project.
Also, thanks to you Mehmet for your kind support during the project. I wish you and your team all the best. I am confident that, although we experienced a few equipment failures, you all will have a wonderful screening room in the end. You are off to a good start.
Let me know if there are any questions.
DAY-8 REPORT (23AUG13):
REC on project.
Tasks Performed:
- Floor rack; DONE
IMPROVED Shifted MiT hanger on rail channel as much as possible (now snug against the cosmetic box frame. Gained a couple of inches. Within 1” of center.
DONE The image dimensions are 14cm x 10cm at the LCD polarizer panel. I would recommend sizing the porthole glass slightly larger than the dimensions of the LCD polarizer glass. This will ensure maximum image width flexibility for future. Also, your porthole position will be positioned approximately 4” forward of the LCD polarizer panel.
NOT ALL DONE Due image alignment characteristics of the Christie Mirage models, the input signal must be input in the correct aspect ratio. Performed an alignment with the only disc available (Avatar). Mike Babb and Peter will perform balance of aspect ratios when they visit.
As I was attempting the alignment of the masking to the various aspect ratios, I noticed to issues:
a. The right side masking was jammed
b. The only way to set the masking and sizing for this model Christie is with an input signal applied.
We repaired the right-side masking. Was a loose bolt which was catching on the masking cable termination. Since this bolt was one that was attached at the factory, was covered over inside the lower right bottom of the screen area, and covered with felt, it took us 2 hours to resolve the issue. We had to disassemble a portion of the masking to get to the bolt and retighten.
As far as the Christie, I used the Avatar 2D playback and resized accordingly. I set the top and bottom masking inward just enough to cover the springs and screen eyelets, then sized the image to this height. Then adjusted side masking inward to match the image width. The measurements comes out to 2.10:1.
I locked the channel configuration and the settings are done for this image. Further ratios will have to be done by Mike, as you will need a reference BluRay with the various aspect ratios on them in their native resolutions.
Programmed the “USER-1” button on the masking motor controller for the Avatar aspect ratio. All others are defaulted to factory.
9) We are also missing the two small screws that mount the z-screen fan assembly.
10) While attempting basic 3D playback of Avatar, found that the MasterImage MI-WAVE 3D unit has a fault with the LCD polarizer screen. Troubleshooting with MasterImage engineering now. Applied all 3D suggestions from MasterImage engineering, and the 3D issue persists. This will have to be repaired when Peter and Mike come over. Did not receive any information from Brand X Headquarters
11) Measured outdoor camera mount location. The glass safety barrier around the parapet is 135cm high from finished floor.
