AVS › AVS Forum › Display Devices › Screens › PULLDOWN OR MORTORIZED SCREEN??
post #1 of 2
Is there any quality difference between a manual pull-down screen and a motorized screen?? If so, what should I be looking for and by who? Recommendation??
Elements:
Basement open HT 15' x 26', minimum light, 2 rows of seating with rear 9' long counter table (3rd row)
60" Plasma HDTV mounted on wall
External Definite Tech Speaker system
Looking at a 110"-120" screen ceiling mounted
Most of the daily watching will be on the plasma, movies and events on projector.
post #2 of 2
Usually you are limited in fabric choices for manual screens. In other words, the better fabrics come on the higher priced tab-tensioned screens.
  Back to Forum: Screens
