AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Pioneer SC-72 Zone 2 Speaker Output
post #1 of 3
Hello,
I'm new to the forum and I have searched for the answer to my question, but have had no luck. I just purchased the SC-72 and am trying to get the Zone 2 speaker outputs to play the analog CD input. It will play the tuner through the Zone 2 speakers, but it will not play anything that is plugged into an analog input. I know it will not play digital sources, which is fine, but I have an analog source I would like to play from Zone 2 to my back patio. The source will play fine from the main zone so I know it is not the input and I know i have the setting for Zone 2 correct because it will play the tuner. Any help would be appreciated, I hate to think a receiver of this caliber could not accomplish what my old H/K could.
Gear mentioned in this thread:
post #2 of 3
Did you try using the SIGNAL SEL button on the remote to manually select analog audio? by default its set to Auto and should have detected analog but...
post #3 of 3
That is probably one of the few things I have not tried, I will give that a shot when I get home from work. I also have a video issue from one input that will sometimes give a pink overlay to the picture or drop out entirely. Swapped cables with same result, have not tried alternate HDMI input on receiver yet. Thank you for the response.
