AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › b&k ct 600.1 remote control
post #1 of 4
I am trying to figure out how to control individual zones from the remote control the ct 600.1 comes with (mz-128) Does anyone have a clue on how to do this? is there a order of operation? the outputs on the b&k are labeled a-f, these do not exist on the mz-128.
post #2 of 4
I responded to your PM to me a couple of weeks ago..... was there nothing of value in my reply? confused.gif
post #3 of 4
this is my first forum, i am still getting used to the navigation. im sorry i did not reply. ive been on this job forever trying to complete it and im almost there. its a complex system because i am integrating bitwise touch" i-pad app" with a RTI system. i think i have narrowed it down to code set 13-17, how ever, i cant find these code sets. i can control the system just not one individual zones. if you could send me a link to get these codes that would be awesome!
Thanks Nick
post #4 of 4
I'm unsure what code format you're looking for, but here's a good starting place:
http://www.bkcomp.com/fileadmin/content/bk_support/Protocol/CT_600X_20005.pdf
...it contains all the available serial & IR hex codes (+ command formats) needed to control your 600.1 - check it out to see if there's anything you can use.
.......and these are the hex codes that relate to multi-zone commands for B&K's 'own' remote (the SR10.1, which I believe would be compatible with your MZ-128):
http://www.bkcomp.com/fileadmin/content/bk_support/BK_Hex_commands/BK_SR_10_1_MZ.zip
Edited by DGF - 8/20/13 at 5:32pm
  Back to Forum: Home A/V Distribution
