AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Will Onkyo 929 or 3010 support front wides and highs?
post #1 of 6
Right now I have the onkyo 818 and taking delivery of the 929 today and sellin the 818....I have all focal speakers and right now my setup is 7.1 with front wides as I do not have enough room behind me for rears...
the room is 24' across by 14'
I have 2 extra speakers that I could run as front high speakers but I have never heard them setup like that and dont know of the receiever will do both fronts and high.....will the highs make a BIG difference or is it not so much?
any other info would be appreciated.
as of now I do not plan on doing 11.2.
post #2 of 6
Can you even have BOTH front wide and front high speakers since I do not have any surround rear speakers?
post #3 of 6
bump??
post #4 of 6
With the 929 DTS NEO X can do both high and wides. You can't run both with PL2Z or Audyssey DSX.
Be sure to give us your impressions.
post #5 of 6
thanks....is it worth trying out? it will be kinda a pita to run the front highs....wondering if anyone had done this and what they think
post #6 of 6
I run an 11.3 system with wides and heights. They mainly play ambient background sounds. Occasionally I'll hear something that sounds like it's high up. I think it's better than running 7.1, but it's not must have.
