AVS › AVS Forum › Industry Area › HDMI Q&A - The One Connector World › [How-To] New Solution for HDMI to PC/Laptop With No Audio
Poll Results: Did This Work For You?
  • 0% (0)
    Yes!
  • 0% (0)
    No
post #1 of 6
New Solution For No Audio Problem
I tried most solutions from the internet but neither of them worked, but after playing with the settings i got a SOLUTION!!!!!!!!!
NOTE: This worked with my SHARP TV but it May work for you biggrin.gif
Here are The steps:
1-Get To The PC Settings On your TV(or something similar)
2-Get to the PC Output Volume (or something similar)
3-Change the Output Volume From HDMI To RGB
4-Voila! The Sound Problem Fixed!
5-If it didn't work, Leave a comment and I Will try my best to fix it! wink.gif
That's It!!
Sorry For My Bad English!
Edited by Tareq178 - 8/20/13 at 1:58pm
post #2 of 6
At the risk of you using an Even BIGGER FONT, what audio problem were you trying to fix? I'm not aware of any audio problems with Sharps and HDMI. Please educate me.
post #3 of 6
The problem is after you set the hdmi as default audio device, and if it still doesnt work , this is the solution
Oh, then the problem doesn't exist for you, its only for who cant hear the audio coming out from the TV nor the Laptop/PC.
Edited by Tareq178 - 8/20/13 at 10:41am
post #4 of 6
No comments?
Feel Free To comment!
post #5 of 6
I have a suggestion for the future:
RTFM!
BTW your English is fine.
Edited by Colm - 9/2/13 at 5:44pm
post #6 of 6
Originally Posted by Tareq178 View Post
No comments?
You are not getting comments because no one else is having this problem. It's good that you let people know about a potential solution but you are probably not going to hear back unless someone happens to hit this same problem.
I use a Sharp daily with my computer without any audio (or video) problems. In the future if you want to explain a potential solution, you might include model numbers as well.
