I just purchased a 64" F8500 which I really like. When I use black optimizer, something funky happens. There are random white flashes. I was finally able to capture one with a camera and it turns out the image is part of what is being displayed on the screen but only in white. I have disconnected the TV from power and also reset it to no avail. I have seen this when hooked up to DVR or blu-ray player. If I turn off black optimizer, then the issue never occurs. I have also disabled Motion Lighting, Energy Saving and Eco Sensor to verify those are not the issue. I am on also on the latest FW (1110). If other people are seeing the issue, I will just wait for an update. If not, I will return it for a new one.
I get unnatural stutters when on. Katzmeier from Cnet noted the same thing. I went to my go to motion scenes from different movies and they just werent looking right. I was trying everything and everyones settings. My resolution got more crisp but motion was still off. Went to Cnet and read the review. Turned off black optimizer and now things look the way they should.
Firstly what a great site for info. Appreciate all the help this site gives.
Anyway reason for my post is: I have the same problem as original poster, and a pain to return the refurbished set. So anyone any ideas how to fix,, it's it parts or maybe I can teak apart from turning off the black optimiser as the issue is still there sometimes.
Might just pay for the fix considering I got it quite cheaply anyway so may be with a few hundred dollars.
Interestingly, my 64F8500 developed EXACTLY this problem on March 3, when it was less than a month old. I didn't notice this thread, because the last update before today was February 15, plus it took me a few days to realize that it went away with the Black Optimizer set to Off or Bright Room.
The very strange thing about this is that the first post in this thread was last August 13.
The service tech told me that he had never seen or heard of such a problem before. He spent a lot of time talking to Samsung, and he told me that Samsung had never seen or heard of this problem before, and had no idea what causes it, or how to fix it. Samsung had him take pictures with his cell phone and send them to Samsung, so they could see it for themselves. He said they were completely baffled.
Swapping in a new main board did not fix it.
After multiple service visits over a period of nearly a month, Samsung finally threw in the towel and offered me a refund or an exchange.
My new 64F85400 is being delivered on Monday.
Counting myself, there's four people just in this thread who have seen this problem. I wonder how common it actually is? If this has been getting reported since at least August, it seems like the right hand at Samsung does not know what the left hand is doing.
When the person on the phone at Best Buy was arranging the delivery, out of the blue she said "Those are really great televisions, when they work".
@Shadowspawn - I couldn't agree more. I am wondering why Samsung hasn't clearly identified the issue. I have the option to have my panel replaced via Samsung, but have not decided yet due to the possibility that it would "redevelop" after a few weeks. Unless, you had the issue from day one, and just noticed it a few weeks in? Mine begins the moment I start using the Black Optimizer (Dark Room). I had the main board replaced on mine, too. The issue became more apparent after it. I also have the 1120.1 firmware update, and it did nothing. I think I might just return it. Thoughts?
PS. There are YouTube videos. I'm not sure these links will post:
Looking at your first two Youtube videos, it's exactly the same problem, right down to the portion of the lower panel that is affected.
I'd return it for sure. Samsung seems to be baffled about what causes it, and a mainboard swap has been proven to not fix it, and it cannot get better from here.
Samsung needs to step up and pay for the consequences this defect, which seems to be cropping up a lot, given that only a small minority of buyers are posting on this forum.
EDIT: I just noticed that your 64F8500 panel is wall-mounted.
As mine is.
Which leads me off into wild speculation about whether there is a mechanical design defect on the TV, that stresses something off the mainboard when it is wall mounted, and causes problems.
BTW, tomorrow I am getting delivery of my THIRD 64F8500. First one developed the ghosting problem in less than a month. Second one, the ARC quit working after ten days.
Hoping for better luck on the third one...
I have to wall mount it. I don't have a single piece of furniture in the house that is wide enough to properly support the ends of the stand.
Hmmm, my 60F8500 does not have this, but I do plan to wall mount it next year, and I want to rule out the possibility of this happening. So far, it seems that only people with 64F8500 have reported this issue. Is anyone aware of any 51 or 60 inch models with this issue?
I am thinking that it could also be overheating issue if you install a wall mount that is low profile and keeps the tv flush with the wall. 8500 series pumps out a lot of heat.
My wall mounted 64F8500 that had this issue is on a fully articulated arm well out from the wall, so it actually gets better air circulation than if it were on a stand mount.
It does seem to run a bit hot, though. I keep the cell light at 18 while watching cable TV or Netflix, which is a good deal of the time.
I need to clarify those YouTube videos are not mine. Those are videos of two different people that posted the issue on YouTube.
Unfortunately my TV is not wall mounted, and sits on top of a stand and it is approximately one foot from the wall, and has enough ventilation for a cooling.
In any case, my 64 inch does exhibit an identical issue to the one in the YouTube video and as everyone describes.
Samsung will replace my panel, meaning they are offering to gut it and put a new panel in the bezel. The bezel would be original. That's where I'm not sure it's worth keeping. -- thanks for the suggestion ShadowSpawn.
Exact same problem here, not wall mounted. TV is about a month old, maybe noticed it once or twice before. Noticed it like crazy today. Glad I found this thread, I was pulling my hair out trying to figure out the issue. Receiver, HDMI cables etc.. Nope, it's this damn back optimizer. I have it on bright room now and problem solved. Already on my second TV due to a dead pixel on the first. Don't really want to deal with another swap out. On firmware 1120. Hoping they can fix this in firmware.. Anyone have any luck fixing this problem yet without a new TV? Luckily it's far less annoying than the dead pixel and I am not sure how much I even care other than I spent a ton on this TV and don't like having to just "deal" with a problem. But I am in no real rush right now with it on the bright room setting. Figured I'd just jump in to say "me too" for others to find and no it's not from hanging on the wall.
Originally Posted by TrickyT /t/1486943/samsung-f8500-black-optimizer-issue-anyone-else-experience-this#post_24679710
Most do not have this problem. So if you are having this issue, I highly doubt a firmware fix will help you. BO works perfectly for me. My advice is to get it replaced if you can. I wouldn't be surprised if you start having other problems with your tv. If a tv goes bad, it usually starts within the first few months. Looks like it's starting on your tv.
Ya, I probably will. Just pissed. I spent weeks dealing with the first problem and was so happy and content after getting the new one like three weeks ago. Everything was perfect until a few days ago. I just have the black optimizer off and it's perfectly fine. Hell, I can't even tell the difference with it off. But for the price of this, I probably should get it fixed. I assume at least this time I don't have to pack up and returning. They just come out to your house correct? And to your question on the other tread. Yes it's the 64" one.
My experience was that I finally got Samsung to agree to replace it (after a month of scheduled repair visits, where Samsung kept telling the contract service guy that this was a problem they'd never heard of and was a new mystery). The Return and Exchange Department called me and gave me two choices:
1. Go buy a new F8500 from any authorized retailer, send Samsung a copy of the receipt, and they would mail me a check for my original purchase price and send a trucking company out to pickup the old F8500.
2. Have them issue an RMA exchange number to Best Buy, and Best Buy would come out and deliver the new F8500 and take the old one away.
I was originally going to go with the first option, to puff up my membership status at Best Buy. Then I realized that Samsung also wanted to take away the nice sound bar that was bundled with the F8500 (and that bundle no longer exists); the 64F8500 was $100 more expensive than in January, so I'd be out $100 and the $250 sound bar; and the fact that the TV had a different price was going to screw up my Square Trade protection plan.
I went with 2, and was happy enough.
In another thread, I was really worried that Best Buy just exchanged (for a different issue) my second 64F8500 with a March build date, for one that had an August 2013 build date. That seems suspicious, to say the least. However, there seems to have been a rash of this problem happening recently, so maybe I'm glad I have an older build date after all.
Originally Posted by shadowspawn /t/1486943/samsung-f8500-black-optimizer-issue-anyone-else-experience-this#post_24681136
I wonder if the evolution kit coming out this month I think?? Would resolve this assuming it bypasses the defective motherboard. Would be interesting to try as I plan on getting it anyway. I also got the full four year replacement warranty from Best Buy with this, glad I did at this rate. Regardless, I'll call Samsung about this, luckily it doesn't really affect watching TV as I just turned off the Black Optimizer.. The dead pixel on the other hand with the first set I had, made me want to punch babies.. Freaking annoying the defect rates on these things. Great TV when it works..
Originally Posted by TrickyT /t/1486943/samsung-f8500-black-optimizer-issue-anyone-else-experience-this#post_24681295
If by "motherboard" you mean "mainboard", replacing or bypassing the mainboard won't fix it. That's the first thing that the contract service guy tried (it's a quick and easy fix, using an easy to handle part, that covers a lot of ground). We were both a little surprised when the mainboard swap made no difference.
At this point, I am sort of suspecting the plasma panel itself.
One of the things that (I have been told) the Black Optimizer does is to utilize the full white gamut at the top end. Most program material does not have white levels above 235 (although things like the PS3 console do). The F8500 is capable of displaying white up to 255. I've been told that, if the program material does not have white levels above 235, the BO scales the whites up to the full range that it is capable of displaying.
My suspicion (and that's all it is) is that the flickering ghosting we are seeing is when the BO scales the whites up, it somehow overdrives something in certain panels and causes cross-talk.
I'd sure like to hear the real story someday.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
