AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Onkyo 609 speakers setup
post #1 of 3
Hello, I have a setup with only Polk speakers
Subwoofer, 2 Front RTI A3 and CSi A4 Center....
My question is on the 2.2 configuration .... is
FRONT = Full Band
Center = 60Hz
The correct setup? Currently I hear a "rain" sound from the central....just checked the cables and they seem to be firm.
Problem is in silent moments... you can hear it and its audible....
Thanks for any help/tip!
post #2 of 3
If you have a sub the fronts should not be set to "full band". Cross them at 60-80hz or there abouts...experiment to find the appropriate setting for your room and speakers.
I don't know what you mean by "rain" sounds....
post #3 of 3
thanks! Today I'll change the Font speakers setup.
the "rain" sound from the center speaker.... is more of a noise...static...constant, that you can hear when there is no real sound coming out...
