AVS › AVS Forum › Audio › Soundbars › LG Sound Bar with Optical cable to fit Toshiba TV without Optical input
post #1 of 2
I have purchased an LG sound bar with optical cable but my toshiba TV does not have an optical cable input - is it possible to buy a converter in order to get them to work/make them compatible or will it work with jack to jack cable
Thank you!
post #2 of 2
It would help if you'd be more specific. What is the model # of your Toshiba? What audio output(s) does it have? Does the LG soundbar have any input other than optical? The model # of the soundbar would also be helpful.
Unsure what you mean by "jack to jack".
  Back to Forum: Soundbars
