AVS › AVS Forum › Audio › DIY Speakers and Subs › does driver placement matter in a ported box?
post #1 of 4
I'm putting together a tall and skinny ported. Its going in the corner behind the plasma. In order to fit it behind everything and allow the woofer to move with out smacking the entertainment center the best option for me is to put it right at the corner where the port starts.
Never built a ported sub just sealed and horns. I wish i could put it in the center but it doesnt look like it will work.
post #2 of 4
Sounds fine to me.
post #3 of 4
not sure what you are asking.
post #4 of 4
I'm going to add one more cross brace to this so I've got four corners that I can put the driver in. The ideal spot for the driver is rite near the port entrance. I can't put it up high as I'm worried the sub may tip and I don't want to put it towards the port exit (front of the sub) since the driver will likely smack the entertainment center.
but mr pizza says that its fine so i'm going to finish cutting up wood soon.
