AVS › AVS Forum › Audio › DIY Speakers and Subs › Just my modest LilWrecker's build.
post #1 of 56
It's not 16x 18" subs.. It's not a pair of Ghorns & Ohorns, or an array of 24" woofers.. But to me, this is a pretty exciting build!
Two lil wreckers loaded with Stereo Integrity HT15 woofers will be installed into my attic, will look similar to an Infinite Baffle, but with 60 cubic feet of folds behind them. EQ will be with a minidsp, amp is NU3000.
These will be replacing a single F20. The F20 is badass... But I'm sure I don't need to explain my desire to upgrade to you people. I should drop my corner by half an octave, and pick up 10db, at least.... The mouths of both horns will be about 1.5m above the seating position.
Ok, I could talk forever, here are some pics
All the wood cut! I had a kid at Home Depot rip the 4x8 sheets for me... Probably cut my build by hours. I stacked the wood to cut two sheets at once, this makes building a pair quick work!
Oh look what come in the mail today! I have no idea what I'm doing. Better start learning. No time, must build.
Beerpong tournament! Just kidding. It's like a thousand degrees outside, so I moved the build into my "finished" porch. It's only
900 degrees in there.
The cat is not an important tool for the layout, but it doesn't hurt.
After mapping out the horn, I stack both outside boards and drill pilot holes, this makes it easy to mount the final panel.
I almost forgot the driver cutout... This would have been the 4th time I missed this somewhat critical step in a build.
Get the first couple boards perfect, and the rest is a breeze.
4 hours and 2 bottles of PL later, a couple horns ready for bracing.
Drivers will be delivered Saturday, if I can find a few hours this week, I should be ready!
post #2 of 56
Nice work!
I wouldn't trust myself to even attempt DIY myself, what things look like in my brain somehow gets completely lost on the way to my hands... lol
post #3 of 56
Very nice!
post #4 of 56
"But I'm sure I don't need to explain my desire to upgrade to you people."
And just what do you mean by YOU PEOPLE?! :P
Nice build BTW. Im still loving my single F20
post #5 of 56
Thanks for taking the time to document this. I bought the 8 sheets of plywood from HD last night and plan on putting mine together this weekend.
post #6 of 56
If you have any questions, let me know. I have a ton of pics!
post #7 of 56
Maybe I should have built a canoe instead.
post #8 of 56
bowwww
thats what braces are for man, hope you can get it sorted out. what type of ply did you purchase at HD btw?
post #9 of 56
That's nothing...
Braces and clamps will fix you right up.
Try working with ply that's been ripped into strips, then leaned up against the wall for a while. I was really going to get back to it any day. I think it sat that way for 6 months.
post #10 of 56
Originally Posted by BadmanSound View Post
bowwww
The cheapest stuff... I was kind of tempted to try OSB this time biggrin.gif
I already trued up everything and the horns are almost done... Just need hit the edges with a finishing router bit, maybe slap on some paint.... Maybe...
post #11 of 56
that looks good for the *cheap stuff*, I guess it probably has the micro veneer...
post #12 of 56
Yeah it's actually not too bad, I built a pair of speakers with the leftover boards, they came out pretty nice!
post #13 of 56
Soon!
post #14 of 56
I'm shocked by how nice these are!
Edited by Stumbo - 8/24/13 at 1:20pm
post #15 of 56
Almost boom time
post #16 of 56
stumbo,
looking forward for your impression, remember dont play too loud biggrin.gif
cheers
henry
post #17 of 56
I didn't get the chance to fire it up today, I had a couple spare hours to "play" and I spent them messing with my minidsp. What an awesome toy!
post #18 of 56
Got home a bit earlier that I usually do on a Saturday night, so I went ahead and trucked one of the horns in. It was really light and easy to move by myself. You cant see my face, but I'm being sarcastic right now.
Long story short, ran REW and after a couple notches on the miniDSP and a 15hz HPF I watched a few familiar scenes (WOTW, Hanna,Hot Fuzz, Prometheus) and was able to ping my RadioShack meter over 120dbs from my seat.
It was a quick setup so I used my IPR1600 that I was using with my F20. I'll be almost doubling my power (ipr1600@600wRMS vs NU3000@1000wRMS), doubling my horns (2subs vs 1sub, durrr) and cutting my distance from the subs in half (9 feet to about 5).
To be honest, it's retarded loud right now. My Cheap Thrills keep up on receiver power (130watts) but I was running the subs pretty hot and they don't have a ton of output left.
Ill try to get a some outdoor readings once the second horn is done.
The nice thing about a tapped horn vs a folded horn is being able to see the woofer move smile.gif
post #19 of 56
F20 vs lil wrecker
post #20 of 56
wow, that is a MONSTER.... I wish my house could accomodate two of those. frown.gif... or that lilmike would create a low profile vs. biggrin.gif
post #21 of 56
Nice work! Can't wait to see measurements!
post #22 of 56
Wish I had room to build these!
post #23 of 56
Originally Posted by wormraper View Post
Would... say... 13.5" deep be low profile enough?
/shameless plug
post #24 of 56
/shameless plug
Have you tried modeling a single fold horn with the si ht18?
post #25 of 56
Nope - no money to build anything, so it's been a while since I last modeled anything. Next one will be a quad 5" design with extension to a mere 30Hz for music, provided I can afford to even get that one off the ground.
post #26 of 56
Silly question, should I tune the subs individually, or as a pair?
post #27 of 56
Depends on what the room and placement require.
My advice? Start as simple as possible.
post #28 of 56
Added my second wrecker, sounded like butt. One note bass and a dip at 51hz that makes makes Miley Cyruses throat seem shallow. Reran the sweep at the woofers mouth and the response looks almost identical to the projected response, so that location will not be utilized... Really hoping the attic location works out well...
Still digging the single horn by itself.... A lot!
I'm running a 48db/oct at 14hz and it seems to be fine... Any advice, or does it matter?
post #29 of 56
Maybe flip phase on one, sounds like a wicked null there.
post #30 of 56
Gave that a go with no luck, I'll bust out the forklift to try another location... Maybe hire a crane.
