AVS › AVS Forum › HDTV › HDTV Technical › Up grading TV's
Up grading TV's
post #1 of 5
I live in Dallas TX and I'm currently subscribed to DirectTV with they're older dish with one bubble on it and want to up grade my TV's to flat screens. Do I have to up grade to the dish with 3 bubbles or will the same dish work?
post #2 of 5
If you have HD TV's now you do not need to do anything. If not call DirecTV and tell them you are going HD and they will do the rest.
There is another forum that is better for DirecTV then this one. http://www.dbstalk.com/forum/32-directv-products-and-services/
post #3 of 5
I currently have digital tube TV's, do I need the new dish?
post #4 of 5
Satellite is digital. Digital can be SD or HD. I would guess you have SD. If so you need to have everything replaced along with a lot of new equipment. You can do it your self getting every thing you need from ebay, amazon and so-forth.
That is a lot of work and if you aren't tech savvy I would not try it on your own. You will need new tuners or DVR's and DirecTV does not sell them, there is a leasing fee that some take as a purchase price, there are a lot of them on ebay so buyer beware. You are going to be a lot better of having DirecTV take care of you. It is going to cost some money but in the long run it's could be a lot cheaper. Also if you have been with them for a few years they may do the job for free.
post #5 of 5
Your question is confusing. If you are currently using the red, white, and yellow cables to connect to your digital tube TV then, no, you don't need a new dish since flat screen TVs have the same red, white, and yellow inputs. But if you want to watch high definition, then you need a new dish. DirecTV will give you the new cables you need when you upgrade to high definition.
  Back to Forum: HDTV Technical
