AVS › AVS Forum › Video Components › Home Theater Computers › HTPC - Mac Chat › EYETV EXPORTING ISSUES PLEASE HELP!
post #1 of 2
Hello,
I am trying to export files from eyetv to my desktop but I can't change the exporting options. The bubble that says "options" when I choose to export a file is shaded grey and I can't click on it. Please help, I need to be able to change the exporting options in order to export my clips in to Final Cut Pro X
post #2 of 2
Some of the exporting formats give you options to adjust the output; some don't. I don't believe that the H.264 format that you're showing on your screen gives you any options. It behaves for me just as it's behaving for you. You'll have noticed that it's in the category of "Native Format (no re-encoding)", which makes sense. Try selecting a different format for export.
  Back to Forum: HTPC - Mac Chat
