AVS › AVS Forum › A/V Control & Automation › Tweaks and Do-It-Yourself › Surge protector red light on
post #1 of 2
I have the Belkin 12 Outlet Home/Office Surge Protector and in the last couple days the red not grounded light has come on which it wasn't on before. I plugged it into 3 different rooms and the light came on in all three rooms. Is the protector faulty? I can't believe that my apartment is suddenly not grounded.
post #2 of 2
Go get one of these and verify the ground. If this checks out ok then your Belkin is bad. If this still shows a ground problem call your landlord asap.
http://www.homedepot.com/p/Gardner-Bender-120-VAC-Outlet-Tester-1-clam-5-clams-master-GRT-3500/202867894#.Uhe94mRga3k
  Back to Forum: Tweaks and Do-It-Yourself
