AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Best Smart TV for Bedroom - 40-43" New or used?
post #1 of 5
I am looking for a bedroom TV set, but I like it to be smaller than 46" , thin, and to have some smart TV functionalities, including Netflix.
Problem is that MOST better quality TVs start at 46", anything with good viewing angle, higher contrast ratio, etc...
Any suggestions for a high PQ TV? I can even look into used market, as I know there were some higher end smaller LCD/LED TVs made by Sony and others before...
Appreciate any help, insight!
post #2 of 5
32 inch suggestions - some are 720p on the lower end:
sorted by most popular
32 inch
http://www.google.com/#fp=539560a959c7801f&q=32+inch+lcd+tv&tbm=shop
42 inch
http://www.google.com/#fp=539560a959c7801f&q=42+inch+lcd+tv&tbm=shop
46 inch
http://www.google.com/#fp=539560a959c7801f&q=46+inch+lcd+tv&tbm=shop
You did not indicate how much you wanted to spend, and what your source would be.
Suggestions for 32 inch "smart tv"
$300
http://www.amazon.com/VIZIO-E322AR-31-5-Inch-Class-Internet/dp/B007TEH0LC
42 inch
$460 at amazon 400 at walmart
http://www.amazon.com/VIZIO-E422AR-42-Inch-Class-Internet/dp/B007TEE966
47 inch
$649
http://www.amazon.com/dp/B007TEKUYG/ref=asc_df_B007TEKUYG2664678?smid=A3IZSVPJ8MGXZY&tag=sdcbing620-20&linkCode=asn&creative=395105&creativeASIN=B007TEKUYG
One alternative would be to get a bare bones led with a good panel and connect a roku, or some other type of streaming box to the TV.
post #3 of 5
Thanks for those. I am not opposed to the roku way or something like that. But again, I am not sure if anyone is using the best LED/LCD technologies in under 46" size these days? Like to be Full-array or local dimming at lower sizes? I care more about PQ than features I guess.
I know Sony HX850 for instance used a better panel in 46" than smaller ones...
post #4 of 5
See below and you will find some good suggestions not all of them are smart sets but that does not affect picture quality ROKU 3 usually has better picture than most built in smart TV anyway best is PS3 decent wifi BD player is another option not usually as good at streaming quality video as both of the 3's though.
http://reviews.cnet.com/best-33-42-inch-hdtvs/
http://reviews.cnet.com/best-43-49-inch-hdtvs/
post #5 of 5
Thanks. It looks like the Panasonic 42 plasma is a great set. I wish I could find one under 40" though. All of the nicer LEDs seem to be above 43. Otherwise the plasma is definitely still the superior screen.
