AVS › AVS Forum › Display Devices › 2.35:1 Constant Image Height Chat › Table top mount for the CineVista?
post #1 of 3
AVS,
I'm looking at canceling my 5020e order for a 6020 for the ultrawide aspect only my projector will sit on the corner of a dresser. I don't see anything on the Panamorph website but a slider and a cieling mount. How do people mount these on table top projectors?
Thanks again
Edited by snyderkv - 8/26/13 at 9:04am
post #2 of 3
Originally Posted by snyderkv View Post
I'm looking at canceling my 5020e order for a 6020e for the ultrawide aspect only my projector will sit on the corner of a dresser. I don't see anything on the Panamorph website but a slider and a cieling mount. How do people mount these on table top projectors?
Which lens are you looking at? The UH480 comes with a bracket that will allow the lens to stand freely. All you have to do is set the lens down in front of the projector. Nothing more to it than that.
The bracket for the CineVista is too narrow to stand freely. The lens will tip over unless you affix the bracket to the table (or whatever it's sitting on) with some screws.
post #3 of 3
Oh ok I didn't know the CineVista came with a small bracket for custom installation. I guess I could find a small aluminum plate to secure the CineVista with. If anybody has a picture of their tabletop setup please show me. Otherwise, thanks for the assistance.
Edited by snyderkv - 8/26/13 at 9:06am
