AVS › AVS Forum › HDTV › HDTV Technical › Athens, TN: Any hope for OTA at my location?
post #1 of 3
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d46ae6812d95d0a
Attic available. between 15 and 25ft above ground. 15ft towards southwest. 25 ft towards northeast. vinyl siding.
Let me know if more info is needed.
post #2 of 3
Not knowing the terrain, I'd say you have two choices. Trial-and-error from the attic, or a more certain arrangement from the roof. I'd definitely go the latter as attics are multipath nightmares and finding a "sweet spot" that allows you to get all the stations you want could be a maddening process. Or you could nail it first try.
Given the fact you have ALL those mountains around you, I'd say an attic antenna is going to be tough. You lose gain through the hills and from being in the attic.
Whatever you decide to do, keep receipts in case you have to return an antenna.
You're going to need at LEAST a mid-range UHF/VHF-Hi combo antenna. Hopefully, someone more familiar with your area will chime in.
Were it me, I'd get a longer-range combo, slap a pre-amp on the mast with a rotor and put it on the peak of the roof. Rotor's only if you want to pull in Knoxville, too. I'd prefer to have the option.
Another thing to do is drive around and see what everyone else is using in your area. Remember, the higher the elevation, the less antenna they'll likely need.
post #3 of 3
thanks, doc. I think it might be a bit too much trouble for me right now. I say that due to me knowing that my wife and I will be upgrading the house and probably moving to a different area in the region once she finishes grad school. It's a nice area to be able to potentially pick up both cities, but a pain due to the hills and just being far enough away to be a hassle. I'll revisit if something in the near future changes. I appreciate your input and recommendations.
  Back to Forum: HDTV Technical
