AVS › AVS Forum › Gaming & Content Streaming › ReplayTV & Showstopper PVRs › IR Blaster how to program it for 5060 replay Help .
post #1 of 4
Hi guys I got my directv today and it updated the program guide ok . I wondering how it can change the channels .To to hook it up and so forth , Please help me if you can .
post #2 of 4
was wondering if when you change channels in replay and the channel said 265 and so forth and your watching HBO lets say channel 507 but the channel you selected for 265 stays on hbo channel 507 is the IR Blaster working to change the channels . Let me know .
post #3 of 4
u need to find the cable box codes in ur replay , if ur box is not listed u need to install them if available---d
post #4 of 4
where do you place the IR sensor on the directv box . You place it over the box sensor for directv right .
  Back to Forum: ReplayTV & Showstopper PVRs
