AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › safe cord to for samsung f8000?
post #1 of 4
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1736787&sku=U12-41702
samsung says i need a 125v 5amp cord, but thats the only 12ft+ i can find in my area
Gear mentioned in this thread:
post #2 of 4
Should be fine... but you are paying too much... try monoprice.
http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10228
post #3 of 4
tiger direct is local, i could go pick it up today, so the extra 5amp on the cord wont hurt the tv?
post #4 of 4
The TV will only pull the power it needs as long as the wire is sufficient to carry the current. Having the cable rated for more amps doesn't mean that it is going to push too much electricity to the TV. Think of it as the cord being capable of that much power being delivered... but the device consuming the power will only take what it needs.
