AVS › AVS Forum › Audio › Speakers › Can I get a GOOD 5.1 setup for 2k or less?
post #1 of 3
I have a budget I need to stick too, if I could swing this, with receiver included for 2k or less, that would be great. My wiring is in the wall and the plan was to use in-wall speakers.
Ideas?
post #2 of 3
Does it have to be in-wall?
Anyway, I have bought from these guys before, if you don't mind B-stock. I couldn't even tell my Yamaha was b-stock.
Receiver: http://www.ebay.com/itm/Yamaha-Rx-V773WA-7-2-Channel-Home-3D-Receiver-Rxv773WA-Great-Bargain-/281121773661?pt=Receivers_Tuners&hash=item417429d85d $500
Ascend Acoustics CMT-340SE L,C,R + CBM-170SE rear + Rythmik LV12R sub = $1,767 right now (if bought together)
Stands: http://www.amazon.com/Sanus-SF34B1-34-inch-Speaker-Stands/dp/B004STEH44/ref=sr_1_2?ie=UTF8&qid=1377653342&sr=8-2&keywords=sanus+sf34 - you can find them for $130
Total: $2,397
Close enough to $2k right?
post #3 of 3
Check out this Hsu Hybrid 3 5.1 package, contact Hsu and ask them to switch two of the HB bookshelf speakers for their HIW in-walls. Try this Denon AVR-X1000 for your receiver. Remember to use the Audyssey feature on that receiver, it does help. Altogether that will give you a killer 5.1 system for a hair less than $2k shipped.
  Back to Forum: Speakers
