AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Software › Blu-ray discs with multiple movies- Any downside?
post #1 of 6
I was in Best Buy today looking for a Blu-ray and I came across a Quentin Tarantino bundle disc. It has Reservoir Dogs, Pulp Fiction, and Jackie Brown.
I am very new to Blu-ray so I wanted to ask the community if there is any down side to buying a three pack like this. Would I miss out on anything like special features or commentary typically with a disc like this?
Does it vary by disc? I saw a few of them like this, but this one caught my eye.
Here is a link to the one I am talking about.
http://www.amazon.com/Quentin-Tarantino-3Pk-Pam-Grier/dp/B007D0FVRM/ref=sr_1_4?ie=UTF8&qid=1377657904&sr=8-4&keywords=quentin+tarantino+collection
Thanks for any insight.
post #2 of 6
Crap that's a DVD. I didn't notice that in Best Buy. I think I saw some others that were Blu-rays though... so the same question above is still the same.
Here is a good example
http://www.amazon.com/Scorsese-Feature-Goodfellas-Aviator-Departed/product-reviews/B007TBJD1U/ref=cm_cr_dp_see_all_btm?ie=UTF8&showViewpoints=1&sortBy=bySubmissionDateDescending
Edited by pdxrealtor - 8/27/13 at 8:25pm
post #3 of 6
It depends on the title, and how it's packaged. If the standalone version includes a 2nd disc of extras, for example, that typically would not be included in a budget combo pack (unless the movies are bundled together in their own separate keep cases).
post #4 of 6
Thanks. That's the kind of info I was looking for. I normally don't watch extras anyways.
These bundles offer a great value. Just picked up a Scorsese three pack.
post #5 of 6
They may also be older discs that were overproduced, for which new versions with improvements exist (new transfer, lossless sound, etc.)
I'd find a review of the specific sets you're interested in and check them out prior to buying, if things like that are important to you.
post #6 of 6
Good point. Finding decent reviews of combo packs can be a little tough though. Amazon might be one place to look for info.
  Back to Forum: Blu-ray Software
