AVS › AVS Forum › Display Devices › Display Calibration › PD8150 ISF Day/Night Codes?
post #1 of 3
Looks like a 3 button code is needed to access the ISF DAY and Nite memory slots, not sure why that isn't in the users manual.. they tell you that you have to enter a code but don't give it to you.. go figure.. Anyway, just want a third place for a max brightness setup for high ambient light. User1 has the normal settings, user2 has a brighter set and want to use one of the ISF slots for a torch mode..
post #2 of 3
Should be up enter down.
post #3 of 3
Thanks Chad!
