AVS › AVS Forum › Audio › Speakers › Looking for Powered Speakers
post #1 of 14
Hi Guys,
New to the forums so i'm sorry for the noob questions. I am looking for powered speakers. I play PC games and listen to Spotify a lot. I don't have a budget yet because I am in the process of building my own PC. I wanted to know what would be a good budget for powered speakers. I want something that will last a long time and I don't mind spending a little extra to get it.
post #2 of 14
I've had some Audioengine a2's ($199)for about 6 months and am very happy with them as desktop computer speakers. There are several threads in this Speaker forum that discuss various powered desktop speakers and the option of using a relatively inexpensive $20 T-amp and regular speakers. Also, Guitar Center has several brands of powered speakers available to demo in store.
post #3 of 14
Check out the Adam audio powered speakers as well as the emotiva airmotiv line. I love my airmotiv 4's
post #4 of 14
Thanks, I haven't heard of that company before. I'll look them up.
I was initialyl looking at the Audio Engine A5. I've heard really good things about that. I went into my local Best Buy but they didn't really have anything. I will check to see if I have a local Guitar Center. I have reading a lot about the Paradigm shift and KEF X300A. Has anyone heard these? What do you think of them?
I think a budget of $500 should get me some really good speakers.
post #5 of 14
If you have a local guitar center see if they have displays you can audition. take your cell phone or mp3 player and a 3.5mm audio jack (if you have one also take a 3.5mm to RCA converter) and audition the speakers yourself. It's the best way to see if you like the sound produced by a set of speakers.
post #6 of 14
Should i bring my own cables or will they have some I can use?
post #7 of 14
I've got the Audioengine A2s at work and I'm really pleased with them (for the size). I'm considering the A5s for home now based on my experience with the A2s.
post #8 of 14
I would say you're best off bringing your own to be safe, but call ahead and ask them if you don't have the correct cables. I've never actually auditioned speakers at a guitar center so I can't comment any more than what I have :-p
post #9 of 14
I don't think a GC showroom constitutes a good listening environment, to say the least.
post #10 of 14
Thanks for all the help. I am going to go and try to listen this weekend.
post #11 of 14
I think the Kef and Paradigms are out of your budget range.
If you have a local Guitar Center, definitely go listen. You should be able to find something there you like smile.gif
post #12 of 14
Would it be worth increasing my budget to look at those brands? I only want to do this once and don't want any buyer remorse. I have a local Best Buy that has a Guitar Center attached to it. So i'm going to try there first this weekend.
post #13 of 14
Maybe not. Do you like bass heavy music like Dubstep, Rap, Hip Hop or Reggae? Would you like more of a home theater experience with your gaming? If so, you might want to stay with your current budget and save towards a sub.
Also, be sure to budget for a sound card that has decent audio. Many motherboards have pretty crappy sound output on their own.
post #14 of 14
+1. A decent audio output isn't that expensive anymore. This Behringer USB interface for instance has an excellent signal to noise ratio, and is only $30. I would get a monitor with good bass extension. I find many sub setups for desktop computer systems are extra localizable since the speakers are typically so close to the listener. Because of this, I would want some speakers with good extension so the crossover point can be lower than normal, this will go a long way toward defeating localization. I would be looking at monitors with 8" woofers. JBL just came out with a great looking new monitor that ought to reach down to 50 Hz, check out the LSR308. Next to that I would be looking at the Mackie MR8. Nice bass that will mate well with a good sub.
  Back to Forum: Speakers
