Projector Advice
post #1 of 2
Hi guys,
I'm halfway building my new batcave. The size will be 16 ft by 23 ft. I had ordered 133" diagonal 1.0 Gain fixed screen. Any recommendations on which projector will be suitable for the screen? The room will be totally light controlled. With all the walls painted black. Thanks you smile.gif
post #2 of 2
Sounds very similar to my situation. Take a look at the thread "Seeking Projector Advice". Maybe we can learn together. smile.gif
