AVS › AVS Forum › Audio › DIY Speakers and Subs › Theater sub build
Theater sub build
post #1 of 4
I'm building my own sub system for a dedicated home theater. My question for the gurus is what sub setup. I mean I could build 12 18s and have massive bass at a certain frequency while others suffer. Wouldn't building a sytem with say 4 18s, 4 12s and maybe 4 10s cover the bass spectrum much better?
post #2 of 4
You are better off going with a dual car sub, dual PA sub combo, for lower and upper bass.
They complement each other very well.
That's what I did, and it's awesome.
You can't beat PA subs for upper bass, they are 99db/w or better usually, or about 10x more efficient than a 89db/w car sub.
post #3 of 4
A 18" sub shouldn't have a problem going up to 120hz so I don't see why you would mix different sized drivers.
post #4 of 4
It would if anything be worse, and the unnecessary complication of having to tri-amp would greatly add to expense and system complexity. As for the need for twelve eighteens, only the very largest of rooms need more than four.
