AVS › AVS Forum › Audio › Audio theory, Setup and Chat › Pioneer VSX-822 No Sound with iPhone
post #1 of 2
I DO NOT have this hooked as an A/V unit. It's strictly being used as an outdoor receiver for music. I have the speakers hooked up to it and that's it. I connect the iPhone for music, but no sound. Just simply shows a file folder and then toggles back to original setting. Any suggestions or special settings that need to be applied?
post #2 of 2
How are you connecting the iPhone? USB? For whatever input you are using on the receiver, did you make sure the type of input (usb, composite, etc) matches? Nothing in the manual helps?
