AVS › AVS Forum › Audio › Speakers › Def Tech 8020st - center channel recommendation
post #1 of 3
I'm seeking advice for a center channel speaker to pair with my set of Def Tech 8020st towers, pushed by a Marantz NR1403 receiver.
I love the towers, but have recently moved to a new space with a bigger room and have noticed a huge difference. The towers now have a much wider setup, about 10 feet apart, and about 10-12 feet from the listener. I now have to crank the receiver volume much higher, and the sound does not seem as full. I think a center channel would be especially helpful for TV/movie dialogue.
I'm tempted by the ProCenter 1000. Any thoughts or other recommendations would be greatly appreciated, as I'm an audio novice.
post #2 of 3
budget?
look at the CS-8040HD - those should pair well the 8020STs. If not then the PC2000, and lastly the PC1000.
http://www.definitivetech.com/products/center-channel/
http://www.avsforum.com/t/625807/definitive-owners-thread
post #3 of 3
Thanks for your reply. My budget was $200-$300, so I'll probably stretch it to the PC 2000.
  Back to Forum: Speakers
