AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Ugh please help!
Ugh please help!
post #1 of 3
For the life of me I can't get my denon 3806 remote to program to my tv or blu ray player, it would be nice to have a macro setup instead of using all three remotes. Can someone please help me set this thing up before I go crazy lol
Gear mentioned in this thread:
post #2 of 3
Anyone?
post #3 of 3
What are the brands of tv and bluray? By looking at the codes in the manual, it uses UEI code library. There is no bluray code list, and there are no UEI bluray codes listed under dvd. So you're probably going to have use the learning feature on page 52 of the manual to teach each and every command off of your bluray remote to the Denon remote.
  Back to Forum: Remote Control Area
