AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Vertical line on TV LCD
post #1 of 6
Hi everyone.
I need help with my lcd, thanks.
42'' lcd, use to watch tv and play xbox 360 hdmi
How i can fix my tv? It is a vertical line and dark spots.
It looks more videos dark areas, In cartoon shows is not for example, It does not look or is very little.
pd: add two videos
http://tinypic.com/player.php?v=2h6frja&s=5
http://tinypic.com/player.php?v=307z2up&s=5
post #2 of 6
Originally Posted by Ucraniano View Post
Hi everyone.
pd: add two videos
Did you just get the tv? If so take it back and get a new one. My tv of 9 years just got the red line. Mine does go away after the tv warms up, but is there and I know it will get worse. Basically your tv is failing and to fix it you'd be better off getting a new tv. If you didnt just get the tv save up for a new one or if its under warranty have them fix it/replace it for you. As far as the black bars go looks like vertical banding to me which can happen with any tv.
post #3 of 6
That vertical banding is pretty wide. Maybe the T-Con board?
Anyway, that pronounced narrow purple/red line smack in the middle of the banding looks just like the line I had on my LG.
In my case, it was TAB bond failure. (Solderless connection of a data ribbon cable to the panel). I took the bezel off and gently pressed each ribbon cable with the butt end of a screwdriver and found the one with the bad bond. (The vertical line will either disappear or get wider). I rolled up a bit of electrical tape to make a cushion and put it behind the point where the cable connects with the panel, in a slight recess there. When I put the bezel back on, the bezel was no longer pushing the cable out of alignment.
While the above is not really a "fix", but more of a "band-aid", the TV in question has been fine now for 9 months.
post #4 of 6
My tv has 2 years and half. is not new
New picture, mayby helps.
I'm not and engineer and open the TV is not a good idea xd, how much you think it cost to repair?
Thx
post #5 of 6
Assuming TAB bond failure, it will cost more than the TV is worth.
post #6 of 6
And if that is not the problem, there is no possibility that it is software problem?
