AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › pictures via smartphone
post #1 of 10
Can anyone tell me how to post picture via smartphone? If it matters I'm using android galxy skyrocket
post #2 of 10
I think you have to upload to photobucket or similar - I don't think the forum hosts uploads.
post #3 of 10
All you have to do is hit the insert image button and choose upload from my device. It should then give you an option to take the picture.
post #4 of 10
I literally only have a 'reply' button with no other options, not even smileys!! lol
post #5 of 10
Maybe after you hit reply you will have the option?
post #6 of 10
post #7 of 10
Okay so now how do I delete? Sorry for the random pic hahah
post #8 of 10
go to edit on the post with the pic and remove the img.
post #9 of 10
It doesn't work for some reason
post #10 of 10
Nope, only Cancel, Preview or Submit lol
I'm sure it used to work, I will have to check my settings or something...
