AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Pro Amp for passive Subs?
post #1 of 4
Anyone ever use a "Pro style" amp to power a passive subwoofer? I don't really know anything about these types of amps and how well it would work in a home system.
Any thoughts?
post #2 of 4
Probably more info in the subwoofer and diy speakers & subs forums. Also search, there are several threads on the subject https://www.google.com/#q=pro+amp+subwoofer+site:avsforum.com
post #3 of 4
I use one to drive 5 subs.
For a detailed discussion of amps to drive subs, see here.
Long story short:
Advantages are cost per watt, reliability, more reasonable warranty policies.
Disdvantages are looks, often lack of remote on/standby trigger, fan noise, sometimes gain-stage issues, may not fit in media cabinets designed for consumer audio gear. Also, some Class D pro amps may throw off enough RF interference to disrupt radio or OTA HDTV signals. (They are not required to have the same shielding that consumer products are.)
post #4 of 4
