AVS › AVS Forum › Audio › CD Players & Dedicated Music Transports › Suggestions For Value On External Optical Drive For IMAC
post #1 of 7
To avoid overuse on a replaced superdrive that Apple installed on my desktop I need suggestions for a good moderate priced drive to continue heavy downloading into music library that also will play BD,DVD and CD.
So many on market, would value suggestions in the under $100 range.
Thanks:rolleyes:
post #2 of 7
Thanks:rolleyes:
Do you have a USB port?
External USB optical drives are commodity items:
http://www.microcenter.com/product/407565/SE-208DB-TSBS_8x_External_Slim_USB_20_Super_Multi_DVD_Burner_-_Bare_Drive
etc.
post #3 of 7
yes to usb...thanks..guess you like the Samsung...
post #4 of 7
Not in particular. I'd stick to names of actual manufacturers of optical drives if the price premium isn't too much - and this one is like $30 - no sweat!
post #5 of 7
post #6 of 7
Try this:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=8388004&CatId=3634
post #7 of 7
Thanks again....best always😉
