AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Samsung Plasma sound issue after extended "dish point" sound usage
post #1 of 3
I have a 3 year old 50" Samsung plasma which has developed a sound issue.
The other week I was re-pointing my dish and had the "beeep" sound on for like an hour on decent volume level. It wasn't maxed out but probably 70% level since the build in speakers are pretty weak.
After a while the sound stopped and then it just stared to "pop" every few seconds. I finally got signal and tuned to a channel and heard voices so I didn't think anything of it. Later I realized that when a louder scene came on like, explosions, the sound would cut out for a second or two. Every time something louder happens the sound cuts out and in.
Any ideas what it could be? I don't want to invest in a separate sound system at the moment but this is making watching basically impossible.
post #2 of 3
you probably "abused" the "pretty weak" built in speaker.... not much that you can do probably outside of replacing the driver which is likely a "5 cent" one to begin with. Of course, that's not what it will cost if you have to get it serviced.
post #3 of 3
It likely would be cheaper and sound better to connect to an external amp and speakers rather than pay for a repair. Boombox, sound bar, stereo, 5.1 - something.
