AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Benq W1070 - HDMI issues
post #1 of 7
I just recently purchased the W1070 and I can't play any devices through the HDMI connections.
*I tried a blu-ray player and got video, but I couldn't get sound.
*I tried another blu-ray player I had and I couldn't get a picture or sound, but the projector showed that it detected a source.
*Last, I tried Apple TV and I got a picture with sound, but when I went to play any video I got an "HDCP error".
I tried multiple HDMI cables that I had with no luck. I am wondering if there is a setting I need to adjust between the devices to get the HDMI to work properly. I was hoping someone on these forums might have some insight as to what the problem could be.
I am going to go buy a new high speed HDMI cable tonight to see if that will help with these issues.
post #2 of 7
That's gotta be a cable problem right? If your getting hdcp errors I'm saying its the cable. Try a short 3ft one. Or there is something wrong with the projector. Are you running it through a splitter? That could do it.
Also. Make sure you restart everything. Pull the plug for a minute just for fun. Including the projector. Hopefully do that one just once. Is everything grounded properly?
post #3 of 7
I've posted this before. The HDMI connectors are a problem. I trimmed about a millimeter of the plastic from the connector so that there is a small space between the plastic of the connector and the projector body when its fully seated. This fix has worked for several others. I just used a box cutter knife.
post #4 of 7
The Monoprice port savers also work.
post #5 of 7
I bought a high speed slim HDMI and that did the trick. The connectors were slimmer as well so maybe they seated a better connection. I will try and trim down one of my other cable connectors and see if that was the original problem.
Either way thanks for the replies!
post #6 of 7
I bought a Benq from Costco at what I thought was an excellent deal ($899 for the projector and two pairs of Benq 3D glasses) but returned it utterly frustrated after experienced flaky HDMI connections. I think I gave up too soon though by having been turned off by this QC issue.
post #7 of 7
Obviously you did not read the Benq W1070 thread before returning the projector. This problem and the solutions have been discussed a number of times there. Pity it is a great projector.
