AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › NEW LG 60LM7200 Setup
post #1 of 3
Hi i am new to the AVS Forum but i would appreciate if anyone had any input on my current setup.
LG 60LM7200
Pioneer VSK-1021-K
Sony 3D ready blueray
Verizon fios multi room DVR
Definative Audio BI-Amp Front speakers
Definative Audio Center Not sure the model
Definative Audio Pro 1000 sub
Definative audio Pro 800 surround speakers.
In the past i have always just hooked all my components up to the receiver and 1 out the the TV for video.
The new TV i just purchased has me wanting to change this to have the Fios box, and blueray player to directly to the tv so i can use this as a input selector.
Ideally i would like to use the magic remote to control volume on receiver, fios for channels, and dvr functions to make it simple for my wife.
I don't want to loose video quality or sound quality Everything is using HDMI.
If someone could put me in the right direction i would greatly appreciate it.
post #2 of 3
Anyone have any suggestions?
post #3 of 3
If the Pioneer doesn't support ARC (Audio Return Channel), then it's best to hook everything up to the receiver as you had before.
