AVS › AVS Forum › 3D Central › 3D Displays › Any 1080p projector that works with NVidia 3D Vision Glasses
post #1 of 4
I currently have an Acer 5360 projector and use NVidia 3D Vision for 3D. I have invested in six 3D Vision glasses so would like to keep using these if I upgrade to an 1080p projector. Any recommendations? Thanks.
post #2 of 4
I have not checked recently. But I think what your asking is if there are 1080p projectors that are 3D Vision certified? I would think so, don't they have a current list on the 3D Vision website? Back in the day I thought I heard of a 3D Vision glasses emitter that would work on any VESA port, But I have not kept up on it.
post #3 of 4
I am not aware of a projector that supports dual DVI (or Displayport 1.2), which is what you need to feed it with 1080p at 120 Hz (the 3d vision format).
... ok, googled around, seems there are some, but not for us mortals:
https://forums.geforce.com/default/topic/516458/full-1920x1080p-120hz-projector-fl35-wqxga/
post #4 of 4
OK, thanks. I would stop looking as there don't appear to be any in the "consumer" range.
  Back to Forum: 3D Displays
