AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Subwoofer impedence
Subwoofer impedence
post #1 of 3
I'm setting up a small, experimental system to play with a class T amp. I want to dig out and use my old Yamaha YST-SW45 as a sub. Of course, the amp does not have a preamp output, so I'll have to wire all the speakers to the sub and wire the amp to the sub inputs. The speakers I am connecting to the sub are 8 ohms, but the sub is only 5 ohms. What "load" does the amp "see" -- 8 ohms or 5 ohms?
Any help appreciated.
Best,
Brian
post #2 of 3
Your Class T amp will only see the 8 Ohm load.
The subs built in amp will isolate the Class T amp from the subs 8" driver, which presumably is around 5 Ohms because the built in amp is rated for 70 Watts output into that impedance.
post #3 of 3
Stereo 2.0, Thank you. I suspected that was the case, but I didn't want to blow the amp based on an assumption. The amp arrives today and I'm looking forward to playing with it.
Best Regards,
Brian
