AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › URGENT! Is 51f5300 going to stutter???
post #1 of 5
I just ordered a 51f5300, without noticing it doesn't have 24hz handling.
Is it going to stutter badly on 1080/720 sources???
I use mostly my PC as source.
Damn...
post #2 of 5
No,
I have this set
You will be fine, it can handle 24hz content at 60 hz (with 3:2 pulldown being done by the player), at 24hz with cinema smooth off and letting the set do the 3:2 pulldown, or at 24hz with cinema smooth on preserving the correct film like cadence (this is my preference).
post #3 of 5
Hi,
thank you for the reply.
You say you have this set, and that you can turn on/off cinema smooth. As far as I know F5300 doesn't have cinema smooth...
post #4 of 5
bump....
anyone else?
post #5 of 5
It has cinema smooth, its not listed in the manual but its there under film mode, trust me i have this set
