AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › new top 2 choices for my first panel, pulling the trigger tonight so need quick input
post #1 of 6
Panny 50" 1080p s64 for $599
Sammy 60" plasma 1080p I believe model 530 for $899
post #2 of 6
That depends How far you are seating from the display?
post #3 of 6
Ill be pretty far
post #4 of 6
Get the s64, it is a better panel. Check reviews on cnet.
post #5 of 6
Originally Posted by JTurkish View Post
Ill be pretty far
How far is far? The Panny is a better panel like I tolled you before but if you are going to sit 15feet away than go for the bigger one, you won't tell much difference sitting that far away. If you are closer than the S64 is the way to go.
post #6 of 6
Sorry for the vague response. We have one chair about 15 ft away and a couch about ten feet away
