AVS › AVS Forum › Display Devices › Screens › DIY Screen Section › Anyone provide any details on constructino of outside velvet border?
post #1 of 3
So I'm going to be making a 120" AT screen with white over silver spandex. I understand how to go about constructing the frame itself now, but I'm a little confused on getting the black border. I've read people making an additional frame around the first frame, wrapping this in black velvet, and then attatching it to the other frame, but I'm not sure how this is done. I know velvet tape is another option, but that seems too damn expensive. Any links, guides, or explanations would be much appreciated. Thanks!
post #2 of 3
MM has a thread dedicated to exactly what you're looking for. Search "wrapping velvet".
Simple instructions would be to create your frame, wrap your material around it and staple it in place. Then create another frame of floor board, wrap it in velvet, and nail it to your original frame. You want to measure your screen to be INSIDE of your frame, not on top of it.
post #3 of 3
  Back to Forum: DIY Screen Section
