AVS › AVS Forum › Audio › DIY Speakers and Subs › First DIY project....need help
First DIY project....need help - Page 2
post #31 of 40
Vertical version would be nice......so would a horn but that would require a bigger box right?
post #32 of 40
well, a horn is a whole different thing and they tend to get pretty large when shooting for something like 17hz, but can be done. much more sensitive to the driver though.
post #33 of 40
post #34 of 40
post #35 of 40
those pre built subs are the wrong thing. their tuning frequency is almost certainly up around 30-40hz, which is great for a car, but not what you want for home theater.
the marty sub that I linked you to is tuned to around 17hz. that is along the lines of what you want for home theater.
post #36 of 40
Oh, okay. I like the Marty sub but I was curious about the boxes on ebay.
BTW, I think I blew it when I bought my 4 SI subs. I ordered them all with dual 4ohm voice coils. I originally planned on two subs per box and running the voice coils in series and then parallel the two woofers bringing the load to 4ohms per box.
If I ran a single sub per box what's the best way to wire them, 2 or 8ohm? Or am I better off just running two woofers per box? I hope I didn't back myself into a corner. I have two Berringer EP4000 amps available for the subs.
post #37 of 40
You could wire two sub's for 4ohms on one ep4000 bridged.
or you can wire each sub to 2ohms and run the two ep4000 in stereo. Each sub to a single channel.
Edited by Mrkazador - 10/1/13 at 9:08pm
post #38 of 40
Interesting, I did not think the amp could handle a two ohm load....that keeps all my options open...sweet!
post #39 of 40
Is there an advantage to either option? Also what is the preferred way to split the Single LF out to two amps? I see people use the mini dsp and some other equipment that I can't recall at the moment..one made by Berringer.
post #40 of 40
I run my subs in two ohm stereo, not a problem.
I believe 4ohm bridged is the same as 2ohm stereo so I'm not sure if either has a advantage power wise. The best way to split the LFE output is to use a cheap rca splitter like this
http://www.parts-express.com/pe/showdetl.cfm?partnumber=240-127
if you want something fancy
http://www.parts-express.com/pe/showdetl.cfm?partnumber=184-224
or build your own!
http://www.parts-express.com/pe/showdetl.cfm?partnumber=092-112
http://www.parts-express.com/pe/showdetl.cfm?partnumber=100-220
http://www.parts-express.com/pe/showdetl.cfm?partnumber=092-011
